universal joints
universal joints
Postby colinh » Tue 04 May 2010 8:08 pm
About to swap the UJ's on the front propshaft on my 110 300tdi defender. Seems ok after reading the manual however I have some memory of being told that it can be a mare. Is it the bolts which are difficult to get off because you cant get a socket on it?
Colin
colinh
Postby OG. » Tue 04 May 2010 10:06 pm
They can be a mare to get the 9/16" propshaft nuts off, the cups can seize in the yokes and there are 2 different sizes of UJ so make sure you get the right one....
'A person without a sense of humor is like a wagon without springs. It's jolted by every pebble on the road' - Henry Ward Beecher
Helga - Smart Roadster Coupe
Fester - Defender 110 300TDi
Mabel - FC101 Ambulance (Sold)
Thing - Sankey
OG.
Dual Fuel Mod
Postby anthony » Tue 04 May 2010 10:21 pm
and the rollers can go everywhere if you don't keep an eye on them :lol:
anthony
Postby idm » Wed 05 May 2010 1:11 pm
There is a special 'tool' for removing propshaft bolts - it consists of an elongated and thin walled 9/16" socket. I'd done a few before I got use of one of these and couldn't believe how much easier it was.... I then bought one and haven't looked back!
You can buy them here:
http://shop.difflock.com/difflock-props ... -p-29.html
(not essential but does make life easier)
As for changing the UJ's, like what the others said... only tip is lots of grease (helps hold the rollers in) and once you have one cap out it can be used to help push the others out - a suitable sized socket does the same job (maybe a bit better as you can use a smaller one and it won't get stuck!). Also the last one I did required quite a lot of 'persuasion' to get moving - just be gentle with the new UJ!
HTH
This is not a witty signature
1993 200TDI Defender 90 [was stolen, and is found, but may not live to tell the tale :-( ]
2002 110 Double Cab [New Arrival]
idm
Postby Denzil » Wed 05 May 2010 6:54 pm
A large vice helps to press the cups in. I find a large nut a bit smaller than the cup can be used to push them the last bit. Just do it slowly and be careful to keep everything pushing straight. If the cup goes solid with a 1/16" to go, it means a roller has fallen over and you need to get them out and start again!
1971 Series IIA SWB owner
Denzil
Postby gonzolandy » Thu 06 May 2010 12:39 pm
gonzolandy
Postby colinh » Thu 06 May 2010 7:01 pm
Thanks for the tips. I like the look of the prop shaft socket but £20 seems quite a lot given how little use it will get. Is it possible to grind a socket down a bit so it would fit?
Colin
colinh
Postby farmerboy_y2k » Thu 06 May 2010 8:19 pm
colinh wrote:Thanks for the tips. I like the look of the prop shaft socket but £20 seems quite a lot given how little use it will get. Is it possible to grind a socket down a bit so it would fit?
Colin
I've got a propshaft nut tool and it does make it quicker, but 2 open ended spanners does the job.
1985 110 2.5p Hardtop
1993 Range Rover Vougue Tdi
1985 Range Rover Vougue 3.5 carb
1990 110 tdi Hardtop - Current
http://www.yorklandroverservices.com/index.htm Mail order parts and Land Rover serving 01904 625073
[img]http://i35.photobucket.com/albums/d152/Silverywaters/LRO/MARTINFINISHED.gif[/img]
farmerboy_y2k
Camel Toed
Postby colinh » Sat 08 May 2010 8:13 pm
Just a quick thanks,
Got the job done today - turned out not to bad. I bought a 9/16 socket and it went on no probs. Sorted for only a couple of quid.
Colin
colinh
Users browsing this forum: Google [Bot], Purpleflarge and 15 guests
