Brake Disc Removal
They may rust but they are simple - Got a problem? Post it here
Brake Disc Removal
Postby rainbird » Thu 06 Dec 2012 6:20 pm
1989 Classic Rangie without ABS
What is the socket size needed to separate the brake disc from the hub? It looks like some 12 pointed socket is needed to get a grip on the bolt heads and I've got nothing like that in the tool box.
Peter
1989 3.5EFi Vogue SE
rainbird
Re: Brake Disc Removal
Postby Kirmit » Thu 06 Dec 2012 6:34 pm
Hi Pete
It's just a standard double hex socket. Think 14mm or 9/16 of the top of my head.
Pete.
Kirmit
Postby paintman » Fri 07 Dec 2012 12:36 am
Pics of both types here:
http://autospeed.com/cms/title_Using-Ha ... ticle.html
Using a six sided one is preferable on normal 6 sided nuts & bolts as the 12 pointers have a nasty habit of rounding off corners making things even harder to undo!
Postby Lothar » Fri 07 Dec 2012 11:48 am
you will probably need a big breaker bar to shift them too, approx torque setting is FT!
a stupid man with a stupid car and a stupid face that won't get him very far
No longer a Landy owner
Lothar
Postby emmerson2 » Fri 07 Dec 2012 6:04 pm
9/16th and an air gun whips them off.If you don't have an air gun,lay the wheel flat, place the hub into the wheel studs. This will give you something to pull against.
emmerson2
Postby rainbird » Fri 07 Dec 2012 9:09 pm
Thanks chaps
rainbird
Return to Classic Range Rover
Users browsing this forum: No registered users and 4 guests
