Flasher
The venerable workhorse - Got trouble?, Post a question here.
Flasher
Postby SidVecory » Fri 09 Dec 2011 6:07 pm
After fixing my heater matrix and refitting the dash, everything is working fine except that the green warning light, that flashes with the indicator light when a trailer is fitted, is permanently on. The wiring diagram appears to show the connections going to the flasher unit. Could this be the problem ? (and where exactly is it ?).
Discovery 1 300TDi XS 200,000 miles and rising
"It's no use saying 'We are doing our best'. We have got to succeed in doing what is necessary" - Winston Churchill
SidVecory
Re: Flasher
Postby Paul 94 200 TDI dicso » Fri 09 Dec 2011 6:24 pm
Had exactly the same on my 200 tdi (I think) indicaters work but no indication on the dash, trailor indicator flashes once,
It was the relay, and on a 200 tdi it's by the steering wheel shaft under the fuse box cover
Living in the past
Re: Flasher
Postby discool » Fri 09 Dec 2011 7:09 pm
On a 300 series the flasher unit is pluged into the fuse board to the right of the steering wheel.
1997 Discovery ES V8 auto.
Previously for 10 years: 1987 Range Rover Vogue Efi auto.
Previously for 2 years 1985 TVR 350i manual.
STAY FROSTY & USE LOGIC ON DIFFICULT JOBS - Get someone else to do it..
discool
Re: Flasher
Postby SidVecory » Fri 09 Dec 2011 9:28 pm
Thanks chaps, I'll have a poke around in the morning and let you know how I get on :wink:
SidVecory
Re: Flasher
Postby buzziesrme » Sun 11 Dec 2011 6:39 pm
I had dodgy indicators once, nearly ripped the dash appart to solve it. Turned out to be the hazards that were interfering with the indicators. I had just used the hazards before the fault. I pushed the hazard switch a couple of times on and off and it fixed the problem :shock:
If at first you don't succeed, destroy all evidence that you tried
buzziesrme
Member Of Forum Elite
Return to Discovery 1
