how to tell a 5 bearing engine? help needed
Series III giving trouble? Let our experienced readers know, and get a sensible answer.
Postby dustyhorse » Wed 26 Jan 2011 8:33 am
I need to source a 5 bearing diesel series III engine
I always thought it was just a matter of finding one with a red block , but what happens when it has been painted,
are there other tell tale signs, might you be able to tell by the engine number
cheers
Currently own series 1 80inch, range rover 300 tdi manual needs work,300tdi rangerover auto and a 300 tdi defender 110 r reg dropside tipper, what a super bit of kit why didn't Landrover make one?
based in North Wilts
dustyhorse
Re: how to tell a 5 bearing engine? help needed
Postby Mr_Tom » Wed 26 Jan 2011 11:01 am
There will be ribs in the side of the block on a 5-main bearing block for strength.
Also, use the first 3 numbers of the engine number - see http://www.glencoyne.co.uk/engno.htm
For example, mine starts 366 (from that site)
366xxxxxx Series III diesel 2286cc 5-bearing
Hope that helps :)
"Becky" - 1976 Land Rover Series 3 2.25D
1999 Discovery 4.0 V8 - The beast
1984 Land Rover Series 3 2.25P :D
Mr_Tom
Loud Mouth
Postby dustyhorse » Wed 26 Jan 2011 2:00 pm
hi
thanks
where is the engine number?
cheers
dustyhorse
Postby landyrob » Thu 27 Jan 2011 5:55 pm
One other point, the 5 bearing engine has a crankshaft pulley damper where the 2.25 diesel doesn't
landyrob
Return to Series III
Users browsing this forum: No registered users and 4 guests
