P38 leak
The place for Range Rover Advice - Any Model - .
Please refrain from selling items here, advertisments will be deleted without warning or notice.
P38 leak
Postby KCB » Sat 05 Jun 2010 8:48 pm
Whilst looking under the P38 (97 4.6), noticed a coolant leak from the back of the engine running down both sides to the bellhousing, can't see where the leak is coming from above, any ideas, ( there's no power loss and limited amount of top up required)
1997 4.6 P38
1990 RRC V8
2004 Freelander TD4
1997 Yamaha V Max
KCB
Postby rangerovering » Sat 05 Jun 2010 9:31 pm
Are you sure it is coolant and not the air con drain?
Steve
Rocket Sledded 1985 Rangie Classic V8 Manual - 3.5 Serpentine, Full RRC Air Suspension with P38 Gen2 Airbags & 24mpg on petrol
rangerovering
Puppeteer
Postby KCB » Sat 05 Jun 2010 10:09 pm
definately coolant - AC drain is usually clear water - this is red coolant (not trans oil either)
1997 4.6 P38
1990 RRC V8
2004 Freelander TD4
1997 Yamaha V Max
KCB
Postby rangerovering » Sun 06 Jun 2010 2:23 pm
Check for leaking pipes or connections at the back of the manifold, if it like earlier cars the heater take off pipes are there and run through the bulkhead.
There is an O ring problem with the P38 but I think that is internal, usually shows up as wet carpets I believe.
Steve
rangerovering
Puppeteer
Postby KCB » Sun 06 Jun 2010 8:10 pm
Unlike the classic the heater connection is higher up on the left (drivers) side, not in the valley, ( which when these hoses leak generally coolant generally collects in the valley gasket)
The heater connetion is not leaking and would not account for coolant tracking on both sides
still looking
1997 4.6 P38
1990 RRC V8
2004 Freelander TD4
1997 Yamaha V Max
KCB
Return to Range Rover
Users browsing this forum: No registered users and 5 guests
