by freelance » Mon 19 Mar 2007 11:22 pm
freelander is basically a front wheel drive, the ird box which is bonded to the back of the internal diff changes the direction of drive through 90 degrees to transmit drive to rear axle, in the middle of prop to rear is a vicous coupling which detects when front prop is faster than rear and cuts in to provide power to rear axle, a crude but cheaper to engineer than the original David Brown 4x4 system, neverthe less it is suprisingly effective in offroad situations, but it is a system that needs regular health check up.
gimme more power
