What OBD reader?
This is the place for Freelander advice. To post a question or comment you need to register first.
What OBD reader?
Postby Someoldblokey » Tue 31 Oct 2017 10:11 am
Hi. Can anyone advise on an OBD reader that will work effectively with a a 2013 Freelander 2?
There are many out there ranging from a few quid upwards but I have no idea which ones are suitable and if any might damage the system. I recently tried the AA Car Genie but it appears to only work on engine faults.
Someoldblokey
New arrival
Re: What OBD reader?
Postby blueovalcraig » Fri 03 Nov 2017 4:44 pm
If you are looking for a serious bit of kit I thoroughly recommend this
https://www.nanocom-diagnostics.com/shop/product/ncom43
Pricey though but capable of everything from reading and erasing fault codes to programming keys etc. Also loads of support available from the associated forum.
For a basic fault code reader, something like this would probably do
https://www.ebay.co.uk/i/251982654590?c ... 693&crdt=0
HTH
Craig
1999 Disco2 TD5 ES
Image Image
Have a Nanocom for Discovery 2 TD5 if anyone needs a shot.
http://www.scotgrc.co.uk
User avatar
blueovalcraig
Grease Monkey
Postby Si » Fri 03 Nov 2017 5:21 pm
I use a bargain basement EBay special. That said, i’ve only plugged it in once to prove it worked. It reads & clears codes, and gives live data. Buy has no programming functions.
I’ve still got a Hawkeye with D2 software unlocked, and did once threaten to pay the unlock fee for the F2.
2010 Freelander 2 TD4_e GS
2015 Citroen C3 HDi
Labrador & Collection of Poodles.
Once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return. - Leonardo Da Vinci
User avatar
Si
Shrunken Mod
Return to Freelander
Users browsing this forum: No registered users and 9 guests
