Auto dim rear view mirror
Postby fella » Fri 14 Dec 2007 8:57 am
Hi everyone, noticed my auto dim rear view mirror doesnt seem to be working, the compass works fine but it doesnt seem to be dimming at all when headlights shine into it at night is there anyway these can be tested & has anyone else had same problem :?
DISCOVERY TD5 ES PREMIUM AUTO
fella
Postby Urban Panzer » Fri 14 Dec 2007 5:31 pm
Test it by simply shining a torch into the light sensor, from the way mine works its actually not that quick to auto dim (when comparing to my audi) , however, it can be made to dim with a torch no prob
Urban Panzer
Postby Sparky » Fri 14 Dec 2007 5:36 pm
check fuses to the mirror - might have failed for some reason?
1963 SIIA 2.25 P - in bits
1976 3 Door 3.5V8 R/R
2002 TD5 90
Sparky
Postby fella » Fri 14 Dec 2007 7:36 pm
Thanks guys tried shining torch into sensor makes no difference & all fuses seem ok just doesnt seem to want to dim :cry:
fella
Postby Phil R » Sat 15 Dec 2007 12:59 am
Hi,
Just as an add on, to the subject..........Has anyone replaced the normal mirror, with the auto dim, as my XS only has the standard type mirror?
Phil
Series 111 SWB 1972
Discovery xs 3.9 1998
Phil R
Postby ciderdrinker » Sat 15 Dec 2007 5:16 pm
Maybe not the answer you want, but my mirror is permanently dimmed since I ripped it off. It's only use is for looking at the face of the driver behind, and it's often not pretty. If it is a pretty face in the car behind it's just a distraction. Door mirrors are all you need.
110 Hard top - 300tdi
turning black and orange
ciderdrinker
Postby Phil R » Sat 15 Dec 2007 5:36 pm
Well Ciderdrinker,
I only want one because of those [half shaft] that don't seem to know what the dip switch is for! and my trustie Rangie ( which is for sale ) had the said dimmer mirror, which was a God send, at times.
Phil
Series 111 SWB 1972
Phil R
mirror
Postby Paul 94 200 TDI dicso » Sat 15 Dec 2007 5:54 pm
Hi Phil R
why don't you go for color glass on a previous thread that seems to be a good option :lol:
:twisted:
Living in the past
Postby sternyboy » Sun 16 Dec 2007 12:01 am
How hard can it be to lift your left arm to do it yourself!?!
Sarge 110 trayback
200Tdi conversion
sternyboy
Postby fella » Sun 16 Dec 2007 8:18 am
I dont suppose theres a way of turning the auto dim on or off like on the older ones which had a button ? :?
fella
