by discobhz » Mon 16 Aug 2010 8:55 pm
Hi PJ,
When I had air suspension on my Disco I had this problem a couple of times. I just connected Nanocom and raised it up to the height I wanted and stored this ride height. Kinda calibrated the height.
I my eyes not two sensors are the same or will give the same signal even at same height, so I will always recommend calibration with Nanocom or similar. You might get away with just replacing a sensor or sway them around so a different part of the pot is used, but I would still recommend calibration unless you are happy with the outcome.
Hope it makes sense.
Good luck
Best regards
Allan
2001 Discovery TD5 Adventurer, QT Diff guards, TP Steering Guard, Hurst Rock/Tree sliders, Guardian Tank Guard, Southdown Raised Air intake, Modified slimline HD Bumper, SD Highliner Roofrack, Bighorn's, De EGR'ed and TF +2" lift
Nanocom available.
