td5 fuel probs
td5 fuel probs
Postby landroverbob » Sat 14 Aug 2010 7:08 pm
can anyone help with the prob i have now when the disco sits for a while say half an hour and you try to start it you seem to turn the engine over and over before it starts best way to start it is to turn the ignition on a couple of times till the fuel reashes the injectors then it wil start just done head gasket
parts replaced so far
injector seals
fuel pressure regulator
fuel filter
seem to be drawing air help :x
200tdi 90 sold
110 double cab
disco2 td5
landroverbob
Postby Si » Sat 14 Aug 2010 8:26 pm
Have you fully purged the fuel system after changing the filters etc?
Try following the fuel lines from the tank, through to the engine and back. Are there any signs of damage etc.?
2010 Freelander 2 TD4_e GS
2013 Peugeot 207 Hdi
Labrador & Miniature Poodle.
Once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return. - Leonardo Da Vinci
Si
Shrunken Mod
Postby landroverbob » Sat 14 Aug 2010 8:37 pm
Si wrote:Have you fully purged the fuel system after changing the filters etc?
done all this the fuel pump sounds as though it is working over time is there any way to pressure test the system i am starting to hate this disco:(
200tdi 90 sold
110 double cab
disco2 td5
landroverbob
Postby changill » Sun 15 Aug 2010 9:50 am
That sounds like the problem that deadbeatdad has. He has changed the filter and the fuel pump and still no better.
We were thinking that the problem is the injector seals. Not spoken to him for a while, but you might want to have a read of his thread:
http://www.lro.com/forum/viewtopic.php?t=54746
or drop him a PM?
Chan
Only Alcohol Can Save Me Now.............And Humble Pie!!!!
NANOCOM Available in the North West.
changill
The Missing Link
Postby Si » Sun 15 Aug 2010 2:42 pm
changill wrote:That sounds like the problem that deadbeatdad has. He has changed the filter and the fuel pump and still no better.
or drop him a PM?
Chan
It would point towards injector seals, or bleed back pipes. The seals have been changed, perhaps the bleed back pipes may need a good looking at.
Si
Shrunken Mod
Postby dieseldawson » Sun 15 Aug 2010 2:53 pm
Fill the tank if the pump goes quite its the pump whats pulling air in. Ive had the same problom but managed to cure it with a lot of fiddling about.
dieseldawson
Postby deadbeatdad » Wed 18 Aug 2010 12:23 am
Hi Guys as posted on my thread still no change, even with changing the pump filter harness but still is a [half shaft] to start and now its getting after ten minutes of running it cuts out. It only starts again after purging the system and pumping the throttle, but only runs for another ten minutes then have to do the same again. had it to a specialists who cannot find the problem either
yOU CAN GO FASTER BUT MY LANDY CAN GO ANYWHERE
deadbeatdad
Postby martinhollings » Wed 18 Aug 2010 7:39 pm
that is sounds like injector seals
martinhollings
Postby ches » Wed 18 Aug 2010 8:33 pm
non return valve in the fuel filter housing? there is also an air bleed valve in the same assembly, both available as a kit.
ches
Users browsing this forum: Yahoo [Bot] and 10 guests
