3 Amigos PLUS brake warning light - all at once!
Postby Hugo » Mon 02 Aug 2010 6:11 pm
Just happened.
Hill decent, ABS and Traction control amber lights plus the red brake warning light. All with 3 bongs.
I was braking gently at the time
Now, I know the front discs need changing, and possibly the pads as well.
Could excessive brake wear have caused this?
I would quite like to get rid of these to see if they reappear when I brake. Other than connecting it up to a nanocom is there any way I can?
There are no members with a nanocom near me.
Thanks
Formerly 'Snowey'
Discovery 2 TD5 03 Auto - Ex Heathrow Airport Security Vehicle - Frosty
Nissan Primastar DCi100 LWB van - Hercules
Nissan Almera N15 Auto - Tina
Previous cars range from a Lada to a Morris Oxford
Hawkeye for D2 available - PM me
Hugo
Obi Wan Kenobi
Re: 3 Amigos PLUS brake warning light - all at once!
Postby landroverbob » Mon 02 Aug 2010 6:20 pm
Snowey wrote:Just happened.
Thanks
sounds like you need a new wheel bearing around £200 to buy and when it is fitted you will need to get the lights reset :lol:
200tdi 90 sold
110 double cab
disco2 td5
landroverbob
Postby Hugo » Mon 02 Aug 2010 6:26 pm
I wouldn't be so hasty to jump to expensive conclusions.
My approach would be to do what I know needs doing then try to reset the lights to see if they come back.
I know it needs a couple of discs. Do I have the time at the moment? NO
Formerly 'Snowey'
Hugo
Obi Wan Kenobi
Postby T62 » Mon 02 Aug 2010 7:29 pm
Snowey wrote:I wouldn't be so hasty to jump to expensive conclusions.
Absolutely, diagnostics NOT guess-wotsits!
http://www.discoverytd5.com/
CDL Linkages Available For Td5 & V8 Series II Discovery
T62
Postby martinhollings » Mon 02 Aug 2010 9:01 pm
must admit that i get my 3 amigoes from time to time it comes up as o/f front abs sensor wheel bearing is ok and have changed the sensor it can come back after a day or 6 months just carry my nanocom and rest if needed so i would try reset before spending money but the later discoverys need more of a problem than the early ones to keep the lights on and should reset them buy them self so many times
martinhollings
Postby Hugo » Mon 02 Aug 2010 9:53 pm
This is why I'm a little confused that the brake warning light came on at exactly the same time as the 3 amigos.
The MOTs due in September and I was going to put it through the second half of August. I suspect it would have passed before but not now :evil:
Formerly 'Snowey'
Hugo
Obi Wan Kenobi
Postby T62 » Mon 02 Aug 2010 10:38 pm
Snowey wrote:This is why I'm a little confused that the brake warning light came on at exactly the same time as the 3 amigos.
It's quite possible the brake warning light is a coincidental happening. Try pushing the h/brake lever down with a thump. This light came on on mine last year and it was literally the h/brake lever not going all the way home when released.
T62
Postby martinhollings » Tue 03 Aug 2010 9:08 am
i think the only way you are going to find out is to get it pluged in
martinhollings
Postby Discv » Tue 03 Aug 2010 10:01 am
The 3 Amigos can pop up if the brakes squeal. Don't know why.
51 TD5 Auto GS. Now sold -on on it's way to Serengeti National Park
But still happy to share use of my Nanocom.
Discv
Users browsing this forum: MSNbot Media and 9 guests
