disco oil light flicker
Postby spannerrash » Sun 23 May 2010 9:58 am
When coming back from day trip yesterday to local beuty spot my oil light started to flicker I had checked the oil level befor I left and it was ok checked it this morning and still ok anyone any idea what it could be I am thinking oil fillter my self but not sure it is going to get a service next week will bring it forword to monday.
spannerrash
Re: disco oil light flicker
Postby thebiglad » Sun 23 May 2010 10:11 am
spannerrash wrote:When coming back from day trip yesterday to local beauty spot my oil light started to flicker I had checked the oil level before I left and it was ok checked it this morning and still ok anyone any idea what it could be I am thinking oil fillter my self but not sure it is going to get a service next week will bring it forword to monday.
You don't say what car/what year/what engine?
1991 3 door Disco TDi 200.
2006 Triumph Tiger 955i
Postby paintman » Sun 23 May 2010 11:11 am
If all levels are fine & the light goes off & stays off with a slight increase in revs first suspect is the pressure sender switch itself.
Postby trailerfitter » Sun 23 May 2010 11:31 am
paintman wrote:If all levels are fine & the light goes off & stays off with a slight increase in revs first suspect is the pressure sender switch itself.
or the connector to the switch,..... ?
look at this for the position of the switch if it any of the 2 tdi engines
http://www.youtube.com/watch?v=1kdsyKTwUo8
trailerfitter
double-0-didn't
oil light flicker
Postby spannerrash » Sun 23 May 2010 12:41 pm
Sorry its a disco tdi2 H reg done dead on 96 thouw.
spannerrash
Re: oil light flicker
Postby trailerfitter » Sun 23 May 2010 12:50 pm
spannerrash wrote:Sorry its a disco tdi2 H reg done dead on 96 thouw.
:shock: thats an ol' un.
trailerfitter
double-0-didn't
Oil light flicker
Postby Aeromole » Sun 23 May 2010 11:35 pm
Definitely change the oil pressure switch. I've had this happen twice.
The switch cured one, but the other time the camshaft pulley came loose, allowing the camshaft to float. Needed a new camshaft, couple of followers, couple of valve rods, but the old girl still topped 200K miles.
Hope it is your switch.....
Pete
Aeromole
Postby michael2 » Mon 24 May 2010 11:18 pm
I was going down a long hill and decided ( at the time ) to put it into neutral to save a bit of fuel and my oil light flickered on.
Its only done 212 thou miles on an H reg.
So what can I do to check it apart from keeping it in gear !!
Td5 Disco
michael2
Postby gripper » Tue 25 May 2010 7:21 am
replace the switch, they're only a few quid they tend to get crud in and become weak hence the flickering, the recession must be biting hard trying to save fuel doing that unless the hill was about 40 miles long you wouldn't save anything really, also if you're in neutral then you are relying on the brakes stopping you in an emergency as there's no engine braking and less control over the vehicle, personally i wouldn't do it on safety grounds, but back to topic try another switch and it wouldn't hurt to change the oil and filter too if it's been a while.
1990 discovery 200tdi - sold
1959 series 2 v8 - sold
1998 discovery 300 tdi - sold
1995 discovery 300tdi - current (no rot, hooray)
Steve.
gripper
Postby michael2 » Tue 25 May 2010 10:42 pm
Thanks for the reply.
I'll see about getting a switch and fitting it.
Td5 Disco
michael2
Users browsing this forum: No registered users and 8 guests
