TD5 Central Locking not working with plip
Postby andymach23 » Sun 21 Feb 2010 12:33 pm
The plip has stopped unlocking the car. This first happened the other day after the car was left sitting for a few days. I firstly thought that it might be the car battery (plip battery is recent and red light comes on ok!). After I unlock the car using the key, I can deactivate the alarm sounder ok with the plip. The car is also starting ok.
After the car is sitting all night I get 12.1v on the tester with the car switched off. After doing about 40 miles yesterday split between 3 trips, I had 12.5 volts on the tester.
Would a battery on the way out cause the plip to stop working the central locking? Any other ideas?
Cheers, Andy
2000 Discovery TD5 GS Manual
1999 Discovery 300 Tdi Safari Manual (current vehicle)
andymach23
Postby discodaz » Sun 21 Feb 2010 12:54 pm
andy,it sounds like you have the same problem as me and countless others on here.
if you first unock drivers door with key,then blip the other doors,does this work?if so its the same issue.i dont know of anyone here who has sorted this yet.its something thats bugged me for months now.
daz
nanocom available if needed
discodaz
Closet 200 TDI Lover
Postby andymach23 » Sun 21 Feb 2010 1:11 pm
Yes, I think it was working like that yesterday. I'll do another test in a bit to confirm.
Cheers, Andy
andymach23
Postby discool » Sun 21 Feb 2010 1:22 pm
Sounds like the electric actuator in the door lock is faulty, only one thing to do replace the lock, unfortunatly. :)
1997 Discovery ES V8 auto.
Previously for 10 years: 1987 Range Rover Vogue Efi auto.
Previously for 2 years 1985 TVR 350i manual.
STAY FROSTY & USE LOGIC ON DIFFICULT JOBS - Get someone else to do it..
discool
Postby andymach23 » Sun 21 Feb 2010 1:30 pm
Do my battery voltages sound ok?
andymach23
Postby discool » Sun 21 Feb 2010 1:43 pm
andymach23 wrote:Do my battery voltages sound ok?
They do no problems there.
discool
Postby Cyberprog » Sun 21 Feb 2010 2:41 pm
Yup +1 on the diagnosis, if the other doors unlock on the second plip, the actuator is the fault, and you'll probably be able to open the drivers on the key.
RHD, LH Door, FQJ102880
RHD, RH Door, FQJ102890
LHD, LH Door, FQJ102900
LHD, RH Door, FQJ102910
Alex Threlfall - 99 TD5 Auto + Hawkeye!
TD5 Alived! Intercooler, Samco XDB Hoses, Boost Box, Stage 2 Remap, Ceramic Exhaust Manifold, Stainless Exhaust
TP4x4 Front, Devon 4x4 Rear HD Bumpers, TP4x4 Steering Guard, Terrafirma Shocks, QT Guards, NAS Hitch, Tank Guard, Safari Snorkel, Diff Lock
Cyberprog
Postby andymach23 » Sun 21 Feb 2010 2:45 pm
discodaz wrote:andy,it sounds like you have the same problem as me and countless others on here.
daz
No the plip won't open the rest of the doors and the plip wouldn't stop the alarm sounding too well. When I opened the door after unlocking with the key, I had to press the fob a heap of times to get the alarm off.
I'm afraid now that I'm maybe not going to be able to stop the alarm sounding if I unlock with the key.
The drivers door lock mechanism is opening no problem with the key so I suppose this shows that the issue is more central locking stuff, rather than the drivers door lock failing.
andymach23
Postby Cyberprog » Sun 21 Feb 2010 3:02 pm
Key usually works for opening the door when the system is fubar, but if it's not opening the rest, may be the microswitch on the keyfob. Mine came off and I had a mate re-solder it. Do you have a second fob? This will allow you to test if it's the fob, or the bcu which iirc contains the alarm functions.
Cyberprog
Postby discool » Sun 21 Feb 2010 3:31 pm
We assume the fob battery battery is 100%. There could be a problem with the transmission between the fob and the receiver positioned above the rear head lining it's not unknow for the receiver to go faulty due to condensation in the roof area.
A main dealer has the kit and can to a function test and may the independants as well.
discool
Users browsing this forum: No registered users and 7 guests
