sloppy gear selection td5
Postby shellyounger » Tue 25 Nov 2008 4:27 pm
can anyone tell me if anything can be done to firm up the spring pressure on the gearstick of my td5 . when in neutral centered it should have a small gate to left and right before gear selection , forward or back , any advice greatly aprieciated
shellyounger
Postby Ricky » Tue 25 Nov 2008 7:14 pm
swap the springs, its not a difficult job
Ricky
Postby martinhollings » Tue 25 Nov 2008 7:49 pm
but you will need a drill 5mm drill bit and some pop rivets
martinhollings
sloppy stick
Postby shellyounger » Tue 25 Nov 2008 10:05 pm
thanks gents for ever in your debt
shellyounger
Postby Paul 94 200 TDI dicso » Wed 26 Nov 2008 5:18 pm
martinhollings wrote:but you will need a drill 5mm drill bit and some pop rivets
Fitted rivit nuts to mine last time alot better
Living in the past
Postby martinhollings » Wed 26 Nov 2008 7:17 pm
i have got ot take my cover off again this will be the 3rd time i have got some 5mm machine screws and am going to tack weld the nuts to the bottom of the plate i bet after doing this i never take it off again rivet nuts a good idea if i had got them then i would do that may look in to getting some
martinhollings
Postby Ricky » Wed 26 Nov 2008 7:25 pm
mines held down with large self tapping screws
Ricky
Postby andymach23 » Wed 26 Nov 2008 8:18 pm
I used self tappers on mine, but I noticed that they are sticking out above the gear box like mini daggers. I'll have to watch out for this if (when :( ) I have to take the gearbox out.
Andy
2000 Discovery TD5 GS Manual
1999 Discovery 300 Tdi Safari Manual (current vehicle)
andymach23
Users browsing this forum: No registered users and 12 guests
