Replacing front brake discs on td5
Postby strattonlandy » Fri 16 May 2008 8:59 pm
I've been asked by a neighbour to fit new pads and discs on a 53 plate td5, ive done pads before but not discs do you have to remove the hubs like you would on a tdi or do the discs just use retaining screws to hold them on??
strattonlandy
Postby Ricky » Fri 16 May 2008 9:13 pm
simple on the TD5 its just caliper off which allows the disc to lift off the hub. From memory there may be one small retaining screw
Ricky
Postby strattonlandy » Fri 16 May 2008 9:26 pm
Thanks ricky i thought that would be the case i shall just remove the caliper and then give the disc some encouragement with my universal metal mover!!
strattonlandy
Postby onespanner » Sat 17 May 2008 2:32 am
strattonlandy wrote:Thanks ricky i thought that would be the case i shall just remove the caliper and then give the disc some encouragement with my universal metal mover!!
It will come off easier if you remove the phillips screw that holds it on :lol:
GS Td5 Disco with cctv
onespanner
Postby andiepops » Sat 17 May 2008 9:10 pm
Piece of [freewheeling hubs] just like doing a car :D
Andy
2001 D2
1994 D1
1989 110
1971 Series 2a
andiepops
Users browsing this forum: No registered users and 9 guests
cron
