Alpine lights - removal and replacement
Postby v8m8 » Sun 27 Apr 2008 11:26 am
My alpine lights let in a bit of water and there is a bit of rust around the edges of the rubbers. I'd really like to sort this out as it will only get worse. Is it feasible to remove the Alpine light glass myself and replace the rubbers treating the rusty bits at the same time, or is it best left to the pros? Id guess cut the old rubbers to release the glass and use string in the new rubbers to pull the inner rubber through to the inside to refit - just seems a drama at roof height - easier said than done?? Anyone done it? Anyone know of reasonably priced seals/rubbers??
Paul
Its a Land Rover thing..............
v8m8
Postby discool » Sun 27 Apr 2008 12:33 pm
There was a bit some time ago in a LR mag on job removing, making good and replacing the glass with new rubber seals and u are correct in what u have got to do and the way to do it. Fitting the glass back was easy using lots of sloppy soap.
For me I think I would use a windscreen company to do that part.
1997 Discovery ES V8 auto.
Previously for 10 years: 1987 Range Rover Vogue Efi auto.
Previously for 2 years 1985 TVR 350i manual.
STAY FROSTY & USE LOGIC ON DIFFICULT JOBS - Get someone else to do it..
discool
Postby jiginc » Sun 27 Apr 2008 12:38 pm
Sealed mine with Dr Tolleys Creeping Crack Cure. No need to remove the glass just drip it in and it will find the leak and seal it.
Look here http://www.captaintolley.com/
jiginc
jiginc
Postby Denis O » Sun 27 Apr 2008 2:13 pm
jiginc wrote:Sealed mine with Dr Tolleys Creeping Crack Cure. No need to remove the glass just drip it in and it will find the leak and seal it.
jiginc
You sure that's not a cure for communicable diseases :shock:
Denis O
Postby jiginc » Sun 27 Apr 2008 6:40 pm
It may well be but it still stops water getting in!!
jiginc
Postby dlocke88 » Sun 27 Apr 2008 8:50 pm
getting glass out should be easy, then treat the rust. i would get a windscren company to refit though, rubber will be as cheap as anywhere else and fitting is usually quite reasonable.
1972 series 3 88
Image Image
dlocke88
Postby stageonesimmo » Mon 28 Apr 2008 8:52 pm
Did mine myself last weekend - no glass companies in sight or even any string - thats why there is a central strip in the seal cos its got a lot of give/slack. Still, I've been doing this sort of thing for years and am confident with it, but you CAN do it with just your fingers and a blunt screwdriver..........................
Watch the bloody thing fall out now I've said that! :wink:
When they kick at your front door,
How you gonna come?
With your hands on your head
or on the trigger of your gun?
When the law breaks in,
How you gonna go?
Shot down on the pavement
or waiting on death row?
stageonesimmo
Users browsing this forum: No registered users and 14 guests
