biggest tyres anyone has fitted to replace the 255/55/18
Postby bushy » Mon 26 Mar 2007 11:14 pm
what is the biggest tyre size anyone has fitted to replace the standard 255/55/18 size tyres on a disco 2 and have you had any problems with the new size tyres? i intend getting a two inch ome lift but my tyres are in need of replacement now so i am going to have get new before i do the lift
bushy
Postby charlie716 » Tue 27 Mar 2007 10:28 am
Assuming that you intend to get the lift for off road clearance, you would be better off getting a set of 16" rims as the available tyre sizes in AT / MT are much better, I have a set of AT2's on my 18"s and they are far better than the Wranglers on and off road and have done 35k miles with plenty left.
charlie716
Postby bushy » Tue 27 Mar 2007 8:01 pm
charlie716 wrote:Assuming that you intend to get the lift for off road clearance, you would be better off getting a set of 16" rims as the available tyre sizes in AT / MT are much better, I have a set of AT2's on my 18"s and they are far better than the Wranglers on and off road and have done 35k miles with plenty left.
the lift is not just for off road i like the look of lifted disco 2s and just dont want the tyres to look too small when i get a 2 " ome lift ,i have been thinking about at2s for a while now but dont want to get the standard size if it is possible to fit a bigger profile tyre with the 2"lift fitted,also i would like to keep the 18" wheels i realise that the range of tyres for 16" wheels is more vast than for the 18" and i know 16"rims are better for off road but i would like to stick with the 18"
bushy
Postby H2455 » Tue 27 Mar 2007 8:08 pm
General have just released a 255/60R18 AT2 they will be around 30mm larger in diameter than your current 255/55R18.
H2455
Postby bushy » Thu 29 Mar 2007 7:08 pm
H2455 wrote:General have just released a 255/60R18 AT2 they will be around 30mm larger in diameter than your current 255/55R18.
thanks for this do you know if they will fit or if there will be problems ?
bushy
Postby H2455 » Fri 30 Mar 2007 12:32 pm
I had a word with the importers this morning they say if you lift it first they can't see any problems.
H2455
Postby CarMan » Fri 30 Mar 2007 2:51 pm
Is there a replacement speedo gear available for differing rolling radius tyres, as there is with 90's?
CarMan
Users browsing this forum: No registered users and 14 guests
