defender rear trailing arm upper washer
Postby discosfa » Tue 28 May 2013 10:37 pm
hi
does anyone have the part number for the large flat washers on both sides of the upper bush please,
i have found the front ones
thanks Roy
1995 300tdi defender county
a-bar and spots fitted
straight through exhaust fitted
more to come !!!!
discosfa
Re: defender rear trailing arm upper washer
Postby Ralph » Wed 29 May 2013 12:06 am
rear trailing arm [lower link] parts in http://www.numcat.ru/landrover/p/31/52630/
rear axle Aframe [upper link] parts in http://www.numcat.ru/landrover/p/31/52634/
rear dampers [shock absorber] parts http://www.numcat.ru/landrover/p/31/52633/
not quite clear what your after
Postby discosfa » Wed 29 May 2013 6:02 am
Sorry it is trailing arm chassis end bush
Thanks Roy
more to come !!!!
discosfa
Postby discosfa » Wed 29 May 2013 11:34 am
discosfa wrote:Hi
Thanks Roy
Problem I have is I got a Britpart yellow bush kit but I am unsure if it should have the large washer on the rear of it axle end, as its only got the 4 flat washers for behind the nuts
Roy
more to come !!!!
discosfa
Postby Aragorn » Wed 29 May 2013 4:42 pm
you should have this lot:
http://www.superpro.eu.com/Content/Imag ... 23K_th.jpg
It should be fitted thus:
Trailing arm, big washer, bush, triangle plate, bush, big washer, nut.
Audi V8 Powered 90 - Work in Progress.
(Will sort a more up to date progress thread soon!)
Audi A4 Quattro - The Daily Driver.
Aragorn
Postby discosfa » Wed 29 May 2013 7:52 pm
Aragorn wrote:you should have this lot:
I am missing or do I have to re-use the first washer (larger bore to pass over the smooth round part of the arm ) as I only have the one that fits the threaded part of the trailing arm, I want to get 2 new ones due to my original ones looking crusty and past it .
Roy
more to come !!!!
discosfa
Users browsing this forum: No registered users and 23 guests
