Radiator Grille.
Radiator Grille.
Postby JulianBrown » Sun 29 Jan 2012 12:03 pm
Is it absolutely necessary to fit washers behind the s/t screws which hold the radiator grille on to my 1984 LR90?
I've just fitted a Globeroamer blind and getting washers in the right place is VERY difficult!
1984 'B' reg. Ninety 300Tdi/R380 Truck Cab.
JulianBrown
Re: Radiator Grille.
Postby Ralph » Sun 29 Jan 2012 12:37 pm
put the washers on the screws right up to the screw head & then push the screw into it's hole with the screwdriver then tighten, always works on my 110.
Postby Interlet » Sun 29 Jan 2012 1:44 pm
Doesn't make much difference really, I think the screws are tapered from memory, so leaving washers off will just mean they will be a be a bit tighter to put in.
1998 300tdi 110 Hard Top, slowly becoming overland spec.
Interlet
Captain Calamity
Postby Ralph » Sun 29 Jan 2012 1:51 pm
mine aren't tapered, just big philips head self tapping screws
Postby andyt » Tue 31 Jan 2012 5:51 pm
Just big self tappers, I fitted some stainless ones myself so no more brown rusty screws!
andyt
Postby JulianBrown » Sun 05 Feb 2012 11:53 am
I have bought a set of stainless steel screws & washers to fit my radiator grille.
The design of it means that I need a magnetic screwdriver to drive the screws home.
Problem: My magnetic screwdrivers will NOT "stick" to the stainless steel screws! They stick to ordinary metal screws but not my new stainless ones.
Why is this? Is stainless steel non-magnetic?
JulianBrown
Postby Ralph » Sun 05 Feb 2012 1:24 pm
some stainless has very low magnetic properties, just put a bolb of grease on the bolt head & then line up the screw & hole.
Postby potato head » Sun 05 Feb 2012 2:13 pm
Or Bluetack :wink:
potato head
Users browsing this forum: No registered users and 28 guests
