Hopefully a quick one, there is two sets of weights for Hi-Caps Standard and Heavy Duty...
How can I tell a HD Hi-Cap from a standard one?
MG Mal wrote:My 130 also has double rear spring set,
and the part numbers ( I was told) match MOD HD Spec.
Nick wrote:Thanks for you patience while I've been looking into your request. I've
contacted our Heritage Centre to get the information which you needed. The
following is the published weights for your vehicle in Kilograms.
*Gross vehicle weight:* 3050
*(Gross vehicle (heavy duty):* 3500)
*Front axle: 1200, rear axle:* 1750 (1850 unlevelled)
(*Heavy duty - front axle:* 1580, *rear axle*: 2200)
*Towing *
*Unbraked trailer:* 750
*Trailer with overrun brakes:* 3500
*Four wheel trailer with coupled braking:* 4000
Unfortunately the Heritage Centre have no record of the Mass Authorised
Mass.
landroveroneten.com wrote:Body Style: H -High Capacity Pick Up with/without crew cab
Users browsing this forum: davidwhittaker and 11 guests
