Rear brake drums to disc conversion
Re: Rear brake drums to disc conversion
Postby Raph » Sun 02 Jan 2011 5:02 pm
I didn't even know a disco one would fit - either way not worth experimenting with. I think a "salisbury" is what you're after if you decide to change the whole axle. Though keeping your own axle sounds like a good idea as getting an old axle with unknown innards could be dodgy - in my case the diff was so worn and leaking anyway that anything would have been better, and as it turns out it was a huge improvement, not just for the brakes!
PS I wondered about whether there might be a pressure equalizing valve between front and rear systems, or whether one was needed and whether anything else would need to be changed... got conflicting advice, but in the end I didn't change anything at all, just plumbed in the 3-way union at the top of the diff casing exactly as the previous one had been, bled the brakes and they were instantly brilliant, no further tweaking necessary.
1986 110 200Tdi
Raph
Forum Poet Laureate
Postby farmerboy_y2k » Sun 02 Jan 2011 6:23 pm
A 90/disco/rrc rear axle will bolt staright onto a 110 with a different prop, but as has been said they're not rated for the weight of a 110. Rear disks would be nice but along way down the priority list.
1985 110 2.5p Hardtop
1993 Range Rover Vougue Tdi
1985 Range Rover Vougue 3.5 carb
1990 110 tdi Hardtop - Current
http://www.yorklandroverservices.com/index.htm Mail order parts and Land Rover serving 01904 625073
[img]http://i35.photobucket.com/albums/d152/Silverywaters/LRO/MARTINFINISHED.gif[/img]
farmerboy_y2k
Camel Toed
Postby julian123 » Sun 09 Jan 2011 5:48 pm
i fitted a disc brake axle to my 110 1989 v8. the easiest thing to do is get hold of a range rover rear axle which is has disc brakes as standard. the axle will fit straight on to the 110. the ONLY mod you will have to do is alter the length of the prop shaft to suit. i had to do this as my origional axle was a sailsbury, and the range rover replacement axle wasnt a sailsbury. to get the prop altered should be £50 - £80, no more. once you have the disc brakes fitted, you will notice a difference compared to the standard drum brakes - a well worh mod indead.
julian123
Postby Vulcan Bomber » Sun 09 Jan 2011 7:35 pm
julian123 wrote:i fitted a disc brake axle to my 110 1989 v8. the easiest thing to do is get hold of a range rover rear axle which is has disc brakes as standard. the axle will fit straight on to the 110. the ONLY mod you will have to do is alter the length of the prop shaft to suit. i had to do this as my origional axle was a sailsbury, and the range rover replacement axle wasnt a sailsbury. to get the prop altered should be £50 - £80, no more. once you have the disc brakes fitted, you will notice a difference compared to the standard drum brakes - a well worh mod indead.
Your car is not road worthy.... read this thread to find out why.
1989 110 county station wagon. Costing me the Earth and keeping me busy!!!!!
1997 300TDi Disco XS, with issues, just joined the party
http://www.tvoc.co.uk
The official website of XH558, the only flying Vulcan in the world.
AMD 4 Wheel Drive, Nr Desford, Leicestershire. 01530230023
Vulcan Bomber
Postby reb78 » Sun 09 Jan 2011 7:35 pm
julian123 wrote:i fitted a disc brake axle to my 110 1989 v8. the easiest thing to do is get hold of a range rover rear axle.............
As mentioned before, RRC axles are not rated for the weight of the 110. Whilst i'm sure they work fine, if you have an accident that results in an insurance/police inspection, there is a strong chance the insurance could be invalid as an incorrect part has been used. A salisbury should be replaced with another salisbury (or perhaps a later TD5 axle if i have read other posts correctly).
Edit - VB beat me to it!
reb78
Postby Vulcan Bomber » Sun 09 Jan 2011 7:41 pm
Reb - :D
yes anything factory fitted to a 110 can be fitted to any other 110.
Vulcan Bomber
Postby reb78 » Sun 09 Jan 2011 7:51 pm
Thanks for confirming...... i meant TD5 110, not any old TD5 above!
The number of people that think it is ok to use disco alloy wheels on 110s also amazes me - it should be published more widely that some of these conversions are incorrect. Too many mods are carried out in a haphazard way that could result in unroadworthy and potentially dangerous vehicles......you only have to search back through this forum to see what can happen (sadly).
reb78
Postby farmerboy_y2k » Sun 09 Jan 2011 8:14 pm
reb78 wrote:Thanks for confirming...... i meant TD5 110, not any old TD5 above!
I agree completely, however i know of at least two landy "specialists" that have fitted disco alloys to 110's they've had for sale to make them look nicer on the forcourt.
farmerboy_y2k
Camel Toed
Previous
Users browsing this forum: No registered users and 24 guests
