How to bleed clutch
How to bleed clutch
Postby okeycokey » Sun 29 Aug 2010 10:05 am
grrr, just got in to the car to find when pressing the clutch down that its stuck to the floor. Reservoir completely empty, investigation has found a connection loose and leaking. Have tightened up but now need to bleed the system, i'm off (in a taxi!) to halfords to get an eezibleed system and some fluid. Never done this before, what is the procedure please?
Defender 90 td5 hardtop
RR Sport SuperCharged 2007
Previously: Defender 90 200TDi Soft Top, Defender 90 3.9 V8, Defender 90 200TDi Hard Top, Defender 90 2.5 Petrol Hard Top
okeycokey
Postby paintman » Sun 29 Aug 2010 11:34 am
Follow the instructions with the Eezibleed & you shouldn't have a problem.
Be sure the cap fits properly on your master cylinder & you have a piece of suitable tube to push over the nipple on the slave. Put the other end in a bottle with a small amount of brake fluid, slacke the bleed nipple & when the bubbles stop you're done.
Use a PROPER nipple spanner to avoid rounding off. I usually check before setting everything up with a hex socket to make sure the nipple will undo!
I've had an Eezileed for years & its a great piece of kit, saves all the hassle & makes what are difficult systems easy!
BTW if anyone has a vehicle with a concentric clutch slave cylinder - fits round the gearbox shaft & you need the box off to replace it - it is recommended that you DON'T use pressure bleeders.
Postby okeycokey » Sun 29 Aug 2010 11:41 am
thanks paintman, just got back from halfords to find that the copper nut and washer to fit the cap the pipe are missing!!! grrrrrrrrrrrrrrr - before I spend another £16 in taxis to get another one, I think i should check it's definitely an air problem... the post was empty and I saw fluid from the connection so I tightened that up. The pedal clunks to the floor and then I manually clunk it back to the top again. Is that sure signs of just being air in the system?
okeycokey
Postby okeycokey » Sun 29 Aug 2010 1:45 pm
right, in the end I didn't bother going back to halfords and just blead the system by pumping the pedal (inbetween filling up the reservoir) and I managed to get the pedal back. I don't think the fluid had been replaced for a long while as it was almost black! Fingers crossed that's fixed it and I won't have any issues...
okeycokey
Postby OG. » Sun 29 Aug 2010 2:50 pm
Well done that man. Nothing so satisfying as repairing it yourself.... :wink:
'A person without a sense of humor is like a wagon without springs. It's jolted by every pebble on the road' - Henry Ward Beecher
Helga - Smart Roadster Coupe
Fester - Defender 110 300TDi
Mabel - FC101 Ambulance (Sold)
Thing - Sankey
OG.
Dual Fuel Mod
Postby paintman » Sun 29 Aug 2010 4:00 pm
If the clutch fluid was that bad, how's your brake fluid?
Postby okeycokey » Sun 29 Aug 2010 4:36 pm
paintman wrote:If the clutch fluid was that bad, how's your brake fluid?
That's exactly what I was thinking when I saw it! Will have a look at it tomorrow when(and if!) the wind and rain has stopped...
okeycokey
Postby Litch » Sun 29 Aug 2010 6:34 pm
I have always found that my 90 clutch will self-bleed without the need for an Ezi-Bleed or a second person (I keep the Ezi-Bleed for the brakes where it is excellent). I make sure the clutch master-cylinder is full, undo the bleed-nipple and allow the fluid to run through whilst keeping the master-cylinder topped up. When the new fluid has run all the way through I nip up the bleed-nipple and press the peddle a few times, there is bound to be a little air in the system but I have always found that on the clutch system this will find its way to the top very quickly.
ONE LIFE, GET IT!
Litch
Users browsing this forum: No registered users and 23 guests
